Have not been able to get video on boot to bios
fan moves all connectors cheked and jumpers
? do i return
This is for the EliteGroup P4VMM2 motherboard. Please remove any newly added video card. One done boot the PC. Windows should load & function (Including video display). Yes?
Restart the PC & press the delete key every 2 seconds untill the bios menu loads. Opem the manual to page 33. Change the Primary Graphics Adapter from PCI to AGP. Save & exit the bios. The system will begian to restart. Press & hold the power button untill the PC shuts down. Unplug the power cord from the PC. Install the AGP card & connect any additional power to the video card if required. Double check all data & power connections for good fit before closing case. Re-connect the power cord & start up the PC. You should have display. Allow windows to finish loading & install the AGP software. Than update windows.
Who ever heard a single long beep. This means the video card may not be seated fully & or correctly. Remove the AGP card, blow out the AGP slot with canned air. Take some alcohol dripped onto a cotton swap. Clean the AGP's copper contacts & clean/wipe the copper within the AGP slot as best as possible. Allow time for alcohol to dry. Re-insert the AGP card, firmely & evenly.
Any more troubles? Please list the issue here. Need manual for the EliteGroup P4VMM2? Click on this link: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Good Luck!
Mike
Try also to check your video card.
Mike thats it in a nut shell the only way to get the agp or pci
solt to take a video card is to set the switch in bios no jumpers
etc. in a sense hosed
i hear a long beep before booting my pc
have you tried replacing the memory ?
