SOURCE: Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
SOURCE: Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
SOURCE: I have a canon dr-9080c scanner and it is having
Sounds like you need a new CIS unit, the scan assembly or its lamps are flickering.
Issue resolved. The root software was the canon capture perfect 2.0, perhaps when Adobe 9 pro was installed it changed the root preferences in the capture perfect software. By getting into the capture perfect scanner properties - "more" setting, the culprit was apparent as the default image size had changed. This was not overideable in the Adobe software. Odd but now works great.
