On The Skill Classic Router DH 4200 all I see is the on/off switch, speed, and how to adjust the height and Soft Start but I don't see how to remove the router bit. Does anyone know where I can get a manual for this router?
Push the rubber sleve off the drill bit and up the drill bit then the plastic ring. release the clip around the spindle. Slide the clip and chuck sleve forward and remove the ball sitting in the spindle. You should then be able to pull the bit from the machine. If it does not want to come hold the bit in a vice and tap the spindle off the end of the bit using a suitable punch. Rebuild chuck in reverse.
Make sure the chuck is loose then clamp the drill bit in the vice and give the drill a straight pull ,once its out then put some engine oil down the chuck and let it soak in ,not that fish oil spray stuff .
DW660 is suppose to be a tool free bit insertion and removal. However a wrench may be necessary. If you have loosened the the collet nut either with the collet grip or a wrench and the bit does not come out. Remove the collet nut completely from the tool. Remove the the collet with the bit in it. With a couple of plyers, one use to hold the broken bit the other to twist the collet. Sometimes when the bit is overtighten the collet locks on to the bit so to speak and the collet wont expand back out thus releasing the bit by doing the above it will expand back out and release the bit. Reinstall the collet and collet nut.
I hope this helps, thanks for using FIXYA. Good luck and have a great weekend. Jeff
If you are having trouble turning the chuck to remove the drill bit just wrap a cloth around it a couple of times and use a pair of adjustable channel lock pliers to give yourself a mechanical advantage. If you have loosened the chuck but can't remove the bit just clamp onto the bit with a pair of vise grips and tap them a few times with a hammer while a friend holds the drill for you.
The problem likely is the cutter/chopper filter.
1. Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports).
2. Remove bottom washing arm. Unscrew (Gently but firmily) centre post. Lift arm assembly out.
3. Remove overhead conduit. One screw at back and one at top (Philips #2 screwdriver bit). Rotate whole assembly 45 deg to the right (Clockwise) and lift off of centre post It can then be taken apart to clean.
4. Remove centre post (Pull straight up) Remove 4 screws (Star T-20 screwdriver bit). Lift whole plastic assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at left front (Under the just removed centre assembly). Remove (Star T-15 screwdriver bit) screw and cap (Needs a bit of wiggling to get it free). Remove cutter and filter ( a stainless steel disc with many holes in it). Tt is on a spring loaded pin. Pull the cutter blade foreward and lift the filter straight up. Clean thoroughly. I then ran a 'quick rinse' cycle with everything out, to clean the inside.
6. Reassemble - Good luck! This worked for me.
If I understand this right you can't remove the bit from the collet. If this is true there might be dirt on the collet and you can try and blow it out with compressed air. What I would do if that doesn't help is support the collet nut allowing the bit to hang free and gently tap on the back of the bit and this will remove it. It is possible that you may have overtightened it or the bit has a burr on it. Good luck
