Assuming the drain plug is the pop-up type where you pull a small rod up behind the faucet, you can try the following:
In the cabinet below the sink you will see the rod come down that operates the sink drain plug. There is a horizontal rod connected to this that goes into the drain line with a small round cap. Unscrew this cap and pull the rod out. The drain plug should come up freely from the drain.
After cleaning reinsert the drain plug and be sure the horizontal rod goes into the drain and through the hole at the bottom of the drain plug shaft. Seat the round ball from the horizontal shaft into the drain line and tighten the round cap to hold the horizontal rod in the drain.
I did a bit more searching for you and if the faucet you are using is a Seva, this URL will help you a great deal:
http://www.americanstandard-us.com/asset...
My instructions were for an older unit. The instructions at the URL and diagram #7 show a newer form of sink stopper. Instead of the vertical and horizontal bars, they have a cable and assembly unit.
Please review this for cleaning your sink drain plug.
If you have any questions, please feel free to contact me. My assistance is free and I will be most willing to step you through this.
Be well.
Paul
How do I remove the cartridge from an American standard Williamsburg bathroom sink faucet?
