Bose Acoustimass 10 Series IV Home Entertainment Speaker System - White Logo
Posted on Sep 17, 2010
Which amplifier will suit Bose Acoustimass 10 Series IV Home Entertainment Speaker System
1 Related Answer
Anonymous
  • 8546 Answers
  • Posted on Dec 09, 2010
SOURCE: Is the subwoofer from the Bose acoustimass 10
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
2helpful
HOW CAN I CONECT THE BOSE TO MY YAMAHA AMP THE ONLY WAY TO CONECT THE BOSE IS TO BANANA INPUTS ON MY AMP AND THEY ARE FRONT SPEAKERS BUT THE AMP HAS A SUB OUTPUT
To enable the full potential of a SUB for Yamaha DSP A5 ,
you need to have
a separate amplifier for your Bose Acoustimass System.
The SUB out should be connected to an active subwoofer.
1helpful
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
After five months without any problems, the Subwoofer stopped working and just makes popping noises. Do I need a new one or is there something I can do to fix it?
Sounds like what happened to my Velodyne DLS5000R. The power supply on the amplifier got zapped by a power surge, and fried a transformer or capacitor.
I would bet a Bose amp, like the one in my Velo, is not user serviceable. Velo requires a flat $230 swapout fee where they send me a new one. They don't even fix the one I send 'em; just send a new one. Too bad, cuz if I could open the "cage" that all the guts are in, I could replace a $3 part myself, but they have this thing glued together where it can't be opened.
Which model of amplifier will match the Bose AM 10 series4
There's a pretty decent write up for this speaker system on CNet. The "Speaker System" section calls for an amplifier capable of 10 - 150 watts RMS.
Bose maintains a library on their products as well. You can download FAQs, Manuals and Product Information easily. On the accessories tab, Bose lists an Onkyo receiver for $350 that will work very well with this speaker system. Of course, any quality modern stereo receiver or amplifier with power in this range 10 - 150 watts should provide good results, but better amps will be in the 75 watts and greater range.
I hope this helps - good luck
Front Speaker not working
Yes, ur setting needs to be changed. On fliping the settings u will realise in one of the modes mostly the surround mode the speakers will work.
Thankyou
Appreciate a good rating from you..
1helpful
Can I connect my Bose Acoustimass 5 - Series II to Bravia unit?
Yes, there should be no issues using your Bose speakers with your Sony receiver. Sony has a "hookup guide" to help here -
http://esupport.sony.com/US/perl/model-home.pl?XID=M:products:crmportal&LOC=3&mdl=DAVHDX265
Please rate my answer, thanks.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
