Little Giant VCMA-15ULST, 1/50 HP, 65 GPH - Automatic Condensate Removal Pu Logo
Anonymous Posted on Sep 17, 2010
This is happening to me, too: Model # VCMA-15ULS condensate removal pump switch suddenly began working backwards - it will go on when the float is down and shut off when the float goes up. What is the problem and how do I fix it?
Anonymous
Level 3:
  • Little Giant Master 43,501 Answers
  • Posted on Sep 17, 2010
Anonymous
Little Giant Master
Level 3:
Answers
43501
Questions
0
Helped
10835067
Points
101584
The switch goes bad and that happens sometimes...
I guess you could change the switch but for the price of a new one it isn't worth my time... I junk em and throw a new one in...
heatman101
Testimonial: "Thanks. Now I know the best way to deal with it."
1helpful
2answers
Little Giant 554455 VCMA-20ULS 230V 20' My pump runs when the float is down low in the tank and comes off when the float is high in the tank. So it runs continuous. Has something gone wrong and...
The float switch went bad... probably because of the water...you could replace it, but the parts are hard to get and with the time involved it will be easier and cheaper to replace it...
heatman101
4helpful
My Little Giant pump (554405) is connected to our furnace/cac collecting condensation. It's been working fine for about 5 years. Now it keeps turning on for about 2 seconds and stopping only to repeat...
There could be gunk in the bottom....then the float does not work right and the pump will not pump either...
remove the pipes and/or hoses and then the screws that hold down the top....clean the inside really well and reassemble... that may work,,,, but it may already be burnt up...
if cleaning does not work the replace the pump...you should be able to buy a new one at a HVAC supply house or some place like HD or Lowes...they will be in the 50.00 or less range...
4helpful
Water is dripping rapidly from my VCMA 15ULS. Do I need to replace it? Or can it be fixed?
I assume the unit is overflowing, because the pump is not running. Check th hose connection and be sure the line bringing the water into the pump is inserted in the opening. Can you hear the motor run? You can remove the top, and be sure the float switch is working and that the pump inlet is not clogged with debris. Sometimes you'll get mold and dirt mixed with water clogging the inlet. If the motor doesn't run, and the switch works, then it probably isn't worth fixing as you can buy these from 35.00--50.00
2helpful
My little giant 554425 will not come on
Either the float is stuck or the pump is stuck...
To release the float a good shot to the side of the pump is all that it will take....
If that does not work then a few screws and the top will come off.. the pump is a very simple spinner.. make sure ther is nothing jammed in there...
if that all checks out replace the unit, the motor is shot....
you should be able to find a new one at a HVAC supply house for around fifty bucks...or check www,grainger.com for a replacement condensate pump.
heatman101
The VCMA-20ULS pump is not shutting off
These pumps have a float arm inside that tell the pump when to turn on and off, it sounds like your arm is stuck or broken. The top of the unit can be taken off of the reservoir to check for damage.
Good luck
Top Little Giant Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
