F9 means different things depending on the brand of your range. For example, F9 on a Whirlpool means that there may be a wiring problem while F9 on a Kenmore means trouble with the self-cleaning door latch. Google F9 and your range brand to find out what may be causing it.
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted. Test switches and if there is nothing wrong then replace the EOC.
The F9-3 error code means that either of the two oven self clean latches is stuck so ya need to check and see in both ovens if their is something from obstructing the lacth
if you also get a F9-4 that would mean its just the lower oven
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch. Thanks
F9 usually means that the oven lock is partially engaged after cleaning. Normally, the door unlocks automatically after the cleaning cycle is through. Unplug or turn the oven off a the breaker switch. Leave it off for a moment. When you turn it back on, the error should resolve. As a caution, unlock problems are notorious after cleaning, a long with fried electronic controls. Clean sparingly. Thanks for using fixya.
Check if the orientation of the printing document matches to the paper available in the copier's trays.
Load SEF letter: means Load Short Edge Feed letter (landscape).
