Try to retrieve deleted files with the undelete tool after you have connected the recorder to your Windows computer.
SOURCE: Need to recover deleted file from recorder
Unfortunately this recorder model is designed with flash memory and once the files are erased they are gone. There are some companies that do specialize in flash memory recovery (Olympus is not one of them). You can go to google and search for flash memory recovery specialists. However this is a very costly process as it involves sending the device to these companies for them to do the recovery process.
SOURCE: how can a recover delited recordings from my rca
Follow this:
First things first: DO NOT take any more recordings with the the same recorder that you want to recover files from.
Then take the memory card or hard drive out of your recorder, and connect it to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Then install this software Wondershare Photo Recovery (recover videos and audio files too) on your computer. Then start to scan and see if your deleted files can be got back. Get the program from:
For Windows Version
For Mac version
Remember - Do NOT try & write anything back to your digital recorder(card or disk) until you can recover your files safely! I hope you good luck! Regards
SOURCE: data recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
SOURCE: Recovering deleted files from olympus VN-4100PC voice recorder
Chances are there to recover such kind of deleted files from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP.
SOURCE: recover deleted files from cenix vr-p3490
Try this digital voice recorder audio recovery software. Just install it on your PC, then connect your recorder (the memory stick or card). Then start to scan for the deleted files. It should help you out.
Remember - Do NOT try & write anything back untill you can retrieve your files safely! I hope you good luck. Best regards.
