Our microwave won't heat anymore. The fan, light, turntable, timer all work but it doesn't heat the food.
It is a Maytag microwave. The inner area has the following information:
C5F7NF21M08500
DHHS Code H7NF
Vac 120
HZ 60
Watts 1450
AMP 13.5
CMV1000ADA
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
There are a number of possiblities that could cause this problem. I'll list a web site that has a complete guide and troubleshooting guide on microwaves hope this helps. www.repairfaq.org/sam/micfaq.htm#micnhono
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
