The only clue is that you posted to Television and Video.
All questions need full 'make model (what it is)' as first 3 words.
Check your power source.
You may also have an issue with your outlet. Try plugging the television into a different socket, preferably one not connected to a light switch. Or it could be a problem with your surge protector; if you've been using one, unplug the TV cord and connect it directly to a wall outlet.
May 18, 2021
TV turning on and off by itself? Here's why-and how to fix it
Asurion
https://www.asurion.com > connect > tech-tips > how-to-...
Quora
https://www.quora.com > I-turn-on-my-TV-then-after-a-...
Oct 2, 2018 - It's most likely a fault in the power system. There's a fault that the television is smart enough to sense and shut itself down before anything ...
2 answers · 35 votes: Michael C. McKinney [
https://www.quora.com/profile/Michael-C-McKinney ] wrote a great answer ...
My 75' ONN TV turns on then powers off immediately ...
1 answer
May 12, 2023
Why does my television turn off by itself? Can I ...
Sep 3, 2015
Can I fix a TV which turns off after 5 seconds of ...
Aug 27, 2016
My TV box switched off itself after a few minutes and ...
Sep 13, 2022
More results from www.quora.com
My TV is turning off a few seconds after start up
iFixit
https://www.ifixit.com > Answers > View > My+TV+is...
May 25, 2020 - Your TV may turn off because of issues on those other boards. sure it is possible that this is the power board but it may also be something ...
2 answers · 1 vote: @blamman before you go replacing random boards, I suggest you ...
Turn it on and it turns right off - Sanyo dp50747 ...
Apr 4, 2013
It turns on then will turn off right away - Television ...
Dec 11, 2016
TV Turns On, Shows Logo, and Then Turns Off - iFixit
Feb 11, 2020
Why does my smart tv turn on and off overs and overs ...
Apr 11, 2016
More results from www.ifixit.com
When I turn it on it shuts off after a few seconds. It's a
JustAnswer
https://www.justanswer.com > TV Problems
Dec 15, 2018 - The first thing you would try, is disconnect the set from power, then press and hold the power button on the TV itself (not the remote), for 10 ...
1 answer · Top answer: You're welcome and best of luck to you. Is there anything you need here today?
Help library: LG TV Powers On and Off Intermittently ' LG CA
LG Electronics
https://www.lg.com > Home > Support > Troubleshoot
Jun 24, 2023 - The TV turns off on account of lack of memory/cache overload to clear out a lot of that unnecessary stored information. The occasional alert ...
