https :// www ?????COM
Good web https://detroit.adlist24.com/*******
If it's an older mechanical machine (not computerized), it has probably seized due to old oil that has dried inside the machine. AVOID trying to run the motor until the mechanics free up and run smoothly. Running it could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
SOURCE: repair singer 502 sewing machine
You can get the fears quite easily and fit them yourself and if you email me I can attach full instructions.
[email protected]
SOURCE: i have a singer model no. 507 (hush matic) but don't have a
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
Singer sells manuals on their site (a few you can download for free) at http://www.singerco.com/accessories/manuals.html.
SOURCE: I have a singer 4830C. Is it possible to lower the
No, but it does come with a cover for them so you may do free-motion sewing.
