Master
- Posted on Sep 15, 2010
Re: How iI open a casio 705 woman watch?
Thank you for contacting FixYa.
You will need:
A jeweler's screwdriver- Either flat head or Philips, depending on the model of watch.
A cup or small box-This is to hold any screws.
How to change a Casio watch battery:
- Spread a cloth over your work area The cloth will help you avoid damaging the finish on your watch.
- If necessary, remove the watch band Removing the band gives you easier access to the back plate.
- Remove the back plate For some models this means using a screwdriver to gently pry it open, and others require removing screws. Keep small screws in a container to avoid losing them!
- Take note of the rubber seal Sometimes they need to be reinstalled in the same orientation. You might even want to use a marker to make a small "match mark" before removing it.
- Locate the battery It looks like a small metal button.
- Remove the battery You might need to loosen (not remove) a small screw and slide a latch out of the way. For other models, it's as simple as popping open a strap that is stretched across the cell.
- Install the new battery Make sure it's in the same orientation as the old one. They usually go in with the positive (+) side down.
- Perform a reset Do this by touching one tip of the tweezers to the AC contact, inside the watch, and the other tip to the back of the watch battery.
- Make sure the watch is working properly Carefully lift the watch to do this. Don't turn it over or the watch movement might fall out.
- Reassemble and seal the watch Perform steps one through four in reverse order to reassemble your watch.
Best regards. Jewel
