SOURCE: Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
SOURCE: nec dterm80 light flashing green
For the green light, you can turn it off from DSS. On the bottom left hand side of DSS, it is a message button. You can press the button and then your extension button. The green light will go away from the DSS and on your phone. I hope this helps.
SOURCE: NEC Dterm80 Name change
OK, I got this from somewhere else. But anyways, pick up the phone and dial 700, then dial the extension number, then finally you can punch in the name like you would doing a text message. When you're done, hit Hold, hang up, and hit Speaker twice.
SOURCE: NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
did you ever resolve this issue? We're having the same one today. Thanks!
