Gestetner C7526dn Laser Printer Logo
Posted on Sep 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Transformer blew at our office yesterday, now calling for a service call, error code SC542???
gggg
Level 3:
  • Master 904 Answers
  • Posted on Sep 14, 2010
gggg
Master
Level 3:
Answers
904
Questions
Helped
520692
Points
1791
Sc542 is a fuser temperature error code, which could either be something simple (a bad sensor reading) or something serious (a blown thermostat). Either way you'll need to have your service technician come take a look at it and reset the code. (Unfortunately, turning the printer off and back on won't help.)
How do I clear SC542 error?
That is a fuser fault code will need to repair fuser first. If you buy the fuser might come with instructions to reset code.
Service call sc542
Its a hot section error, not a good one, to reset push in order, clear modes(yellow), 1, 0, 7, hold stop/clear for 5 seconds, if it comes right back service needed. -Carl
Gestetner Dsc445 service code error
have you checked/replaced the thermostats?
this may also be a problem with your hvt board or power supply.
2answers
We had power failure today and now after unplugging it and just turning the power off our Ricoh still has SC542 as an error code- - please let us know as to what we should do- should we try something else...
You should have a service technician come look at the machine. sc542 is a fuser code, which could mean that a thermostat was blown, or it could be a dirty or defective thermistor. A Ricoh technician will be able to inspect the fuser and make that determination, and hopefully get you up and running right away!
36helpful
3answers
1helpful
Error sc 547
Found this from:
http://slayo.com/ricoh-cl4000dn-error-code-sc542.html
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
The error code is now cleared.
Hope this helps!
WizardRepair
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
