Turn off printer and turn back on after 30 seconds to give it a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge devices or power strips, even if the printer previously worked correctly with these, as they can cause low amperage problem which can trigger a false printhead error. You can also try to plug the printer to another known working power outlet just to eliminate the power source as a possible cause of the issue. If error continues, printer may require service. Contact Lexmark technical support or an authorized service provider for further assistance.
