SOURCE: Hi, My SAMSUNG LE40R88BDX/XEU LCD 40
It sounds like the power supply board has some bad capacitors that need to be replaced. Samsung is covering the cost to repair this problem on some models. You can call 1-800-samsung to find out if your unit is covered.
SOURCE: what Uf & voltage capacitor do i need for my
the defective caps in general will be blown upwards there heads will not be flat the value will be indicated on the defective capaciter you must respect polarity .
SOURCE: Hi, My SAMSUNG LE40R88BDX/XEU LCD 40'', isnt working! When you tu
it is a known fault mine was the same the tv was 3-4 years old and samsung fixed for free they will do the same for you give them a call
Hi rajbum88,
This is an indication of out-of-regulation in the power supply section. The very
common caused of this fault is the leaky
electrolytic capacitor in
that section. It will drop the supply from normal voltage and
will disable the unit.It needs a little warm-up to make itself stable but the
symptom will get worst like what you've experienced right now. Sometimes it has a bulged/dome at the top but not all, it is better
that you have a capacitor
checker/tester to determine
its condition. Your unit will back to normal again if the leaky capacitor is
isolated.
If you don't have necessary tools
and test instruments, and can't do the job yourself, I would advice you to
look for a professional to troubleshoot the problem. Don't
attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored
electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty,
avail it because the manufacturer of your unit will fix it for free. Don't open
the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
