HP Compaq Presario V2000 Notebook Logo
Posted on May 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen display goes PINK
My screen has turned pink!
I have the latest graphics driver installed.
Any suggestions or other pinks out there?
ktewell
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 14, 2008
ktewell
Contributor
Level 1:
Answers
Questions
0
Helped
379
Points
Your laptop model is notorious for this problem. It is a loose connection with the wires going through one of the hinges of the flip screen. Open up your computer and find a way to plug the wire all the way back in. It can be a frustrating task so be prepared.
Pau Loo
Level 1:
New Friend:
  • Posted on Jul 06, 2015
Pau Loo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
379
Points
Resolder or bake your video chip.. That's the common problem to most Intel® Cheap Set Products..
Anonymous
Level 2:
Scholar:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 77 Answers
  • Posted on May 15, 2008
Anonymous
Expert
Level 2:
Scholar:
Teacher:
Answers
77
Questions
0
Helped
40372
Points
226
You may need to update or you driver is not compatible with your os system
Screen is pink on my dell dimension 3100
Check your monitor cable first! Try reconnecting your display cable both at the computer and monitor ends. If it's still pink, try reinstalling the vga graphics driver from the Dell Utility CD-ROM (Or download from Dell's support site http://www.dell.com/support/home/us/en/19/product-support/product/dimension-3100/drivers then select you PC model's video driver and re-install it. if after re-installing the video driver your display's still pink, try connecting to a different monitor - if a different monitor displays correctly, then its your monitor that's faulty. If it's pink on a different monitor too, then it's your PC video hardware that's got the problem - At least you'll know whether it's the monitor that's faulty or whether it's your computer's graphics hardware. (if your computer's video chip is faulty, then I suspect you'll need a replacement motherboard - $$$ - as I think the video is "on-chip" on the Dimension 3100 - so it may be time to consign it to the scrapheap and buy a new system if you can afford to)
PINK Laptop screen
1. Plug in an external monitor to your laptop. If the picture on the external monitor is good, then the problem is your laptop screen. If the external monitor also displays a pink screen, the problem is in your laptop hardware or software.
  • 2 Contact Dell if your computer is still under warranty when the problem is with your screen. If your laptop is not covered by warranty, contact a computer repair shop to have the screen repaired or replaced.
  • 3 Update your drivers and bios. Outdated drivers or bios have been known to cause screen issues. Visit Dell's Drivers and Downloadsicon1.png website where you can enter your service tag and find the appropriate updates for your computer.
  • 4 Contact Dell's technical support team if the above steps do not fix the pink screen. Dell has had known issues with the pink screen being caused by the graphics card on some of their laptopsicon1.png. In many cases, replacing the motherboard is necessary to remedy the problem.
  • Read more: http://www.ehow.com/how_6318059_fix-pink-screen-dell-laptops.html#ixzz2n6yCxzw5
    Pink screen
    Is it Intel or AMD? Do you have the correct graphic card driver installed?
    Go here, http://www8.hp.com/us/en/drivers.html locate your product and download the right driver..
    Screen turns pink after login
    While in Safe Mode....
    Go to HP.com, Support, Drivers....
    Download the latest video drivers, including the "Chipset" drivers.
    Then, uninstall all video drivers by going to control panel, (System, Device Manager)
    Reboot system, hopefully Windows will install the correct drivers upon reboot.
    After reboot, re-run the new drivers
    Pink screen abd pink lines everywhere
    hi there.
    for this, kindly check the BIOS mode of your machien first to know if the pink lines will still show there and if it still show then you may wanto contact your acer support to arrange a screen repair or replacment since issues like this are usually cause by dead pixels or display driver problem or display driver updates issues
    you may use the given phone number below to contact the acer support if yoru screen shows the pink colors on BIOS so they can arrange a repair or screen replacment 800-816-2237
    My Epson proxima is displaying pink. I did reset and replace cables and bulb. Any suggestions
    I've seen the screen go pink when the video input is set to the wrong type (composite instead of RGB). Try each input type to see if it goes away.
    White turns to pink on acer laptop
    The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
    3helpful
    Screen goes pink
    First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
    Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
    In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
    http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
    Screen is pink
    have you tried the video settings by right-clicking the desktop then properties>settings tab then either manually change colour support or go advanced. If it doesn't budge, try turning off the system, go to safe mode if it still has a problem, try reinstalling your graphics or video drivers.
    Did you do anything in particular before this happened?
    Pink horizontal stripes on my monitor
    If youve tried pressing the degaus button on the monitor and the same result then either your graphics driver is corrupt and needs to be updated from the manufacturer web site or the monitor is on it's way out. Try a friends monitor on your system or your monitor on a friends, if it's the same on a friends ststem, it's a belated Xmas present for yourself.
    Top HP Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
