SOURCE: lg viewty camera flash not working
This worked for me: I turned the ISO to 800 and set the flash to "auto" - even in quite bright light the flash still goes off so I'd definitely try this. To turn the image stabiliszer off, press the "unlock" button next to the shutter on the side of the phone.
SOURCE: flash on camera not working lg viewty
hi, even i have the same problem, probably i don't think the flash doesn't work, but even i didn't know how to use it. however, the instruction manual says there are 3 options in flash, they are auto- that is it turns flash automatically on when it turns on. red eye reduction that is it says it will flash twice to reduce red eye but i never see the flash on and the flash off, that is it will not turn on and usually whenever you exit the camera the flash will default to turn off mode. you will need to switch the flash back. hope you understand.
