Question about HP nx9110 Notebook
Hp+server+tc2120+flashing+yellow green+power+light Please my Hp server tc2120 wont come on its only gives me green, yellow or orange power flashing light thats all nothing happens after that i can hear only a messy voice
6ya staff
SOURCE:
mailtoravi
Ravi Kumar
  • 186 Answers
SOURCE: hp dv4000 won't power up
Try this solution :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook.
Additionally, try removing and reinserting the RAM sticks by following the instructions listed in page number 119 of 266 :
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
If the issue repeats, try connecting the Notebook to any Desktop Monitor and press the FN and F4 key so that the display will transfer to the desktop monitor connected.
If there is no display on the LCD of the Notebook or on the Desktop monitor connected, issue can either be with the Graphic Card of the Notebook or Motherboard itself.
I am sure these instructions are helpful.
Posted on Aug 13, 2008
Jim Kramer
  • 5 Answers
SOURCE: my hp laptop wont start power light flashes on
try powering up the laptop with the battery pulled. In my case, the battery was the culprit. Probably shorted.
Posted on Apr 21, 2009
Anonymous
  • 4 Answers
SOURCE: I have an HP Pavilion dv7-1245dx and it will not turn on.
Chip of video on motherboard are defectous, reemplace it or the motherboard.
Posted on Jul 20, 2009
Anonymous
  • 59 Answers
SOURCE: Problem HP Compaq nx 7300 Yelllow light 8x
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
Posted on Oct 20, 2009
Testimonial: "I repclaced the charger...no is ok again...thx for the help :-)"
walesarumi
Walesarumi
  • 6993 Answers
SOURCE: HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Posted on Dec 03, 2009
Testimonial: "awesome, thanks, i'll try that :)"
HP Server Tc2120
just go thru this link
http://h18000.www1.hp.com/products/quickspecs/11554_div/11554_div.HTML
kindly describe your problem also.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 27, 2010 | HP Server Tc2120 (335874-001)
A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
Nov 09, 2009 | HP Server Tc2120 (335874-001)
While i was formatting a TC2120 server, i used low level formatting with Ctrl+A option after that the server is not detecting the SCSI hard disk although i've tried to install the third party driver with...
This error message usually relates to the wrong third party scsi drivers being use.
Check what SCSI card you have installed and make sure you have the correct drivers and that you select the correct driver from the list at the appropriate time.
It is also possible that the SCSI card itself has a problem, but it is far more likely to be the wrong driver.
Jun 29, 2009 | HP Server Tc2120 (335874-001)
HP SERVER PROBLEM
You should be using a 110 voltage cable if you are in the USA.
Jun 14, 2009 | HP ProLiant ML350 G5 Server
Connect HP Proliant ML350 Server.
Please verify if your server power specs support 110 or 220 V. If you are in the US, eventhough you might have connected a 220V cable the line voltage can be 110.
Check with your power company if they can provide you the necessary wattage of the server.(Specs are printed on the power supply. you can read it from HP web also)
Once you are sure that, connect both power suppllies and try booting.
If the error still occurs, it can be a power supply failure or some other hardware failure.
Regs,
Jun 14, 2009 | HP Compaq ProLiant ML350 G3 Server
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
HP nx9110 Notebook Logo
125 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
