This
is a problem in one of the damper-related components, either the switch
or motor or the damper door may be binding.
The
damper is a door inside that opens or closes depending on cooking mode.
If the controller senses that the door is not in the right position, it
will shut down the cook cycle.
Sharp (and Sharp-made Dacor and Wolf) models stop after
59 seconds.
See the sample
drawing for a typical damper assembly. http://www.fixya.com/uploads/Howto/B27054B.jpg
We have the applicable
service manuals here and here.
You can order Dacor parts by part number from Encompass here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
CORRECTION! You can order Dacor parts by part number from the Pros here:http://tinyurl.com/gv383
I bought a Sharp Microwave Oven with Sensor, Grill and Convention functions, R-967(SL)M, a few years ago in London, United Kingdom. Problem: Now, each time the timer counts down to 1 second (for example, 1 sec. or 2 mins. 1 sec. or XX mins 1 sec.), the heating function just stop as long as the timer shows 1 second. In addition, I relocated to Hong Kong and the local Sharp customer service refused to provide any repair service (even if paying!) since I did not buy the product model in Hong Kong! The warranty period has ended, hence there is not an issue with warranty service. Appreciate if any expert(s) out there could kindly provide assistance or at least offer a direction/suggestion which I could pursue to get the appliance back to working again. Thank you!
