Sony Cyber-Shot DSC-P32 Digital Camera Logo
Posted on May 15, 2008
Canon A560 Lost 2 days of images
Hi....Was traveling and took a bunch of pictures. When I looked at my images via the camera I was also looking at options in the menu. Don't know what happened, but when I went to have my friend view them, it said no images......Can I recover the images??? Thanks so much in advance for your help.
Arly0015
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Oct 17, 2013
Arly0015
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
5450
Points
15
You may accidentally delete these newly taken photos. In order to get back your lost photos, you should act carefully as below:
Step1. Stop using this camera in case that any new file would rewrite your original data.
Step2. Insert this camera to your computer and prepare to restore your data.
Step3. Download a deleted photo recovery freeware to your computer and start to retrieve all your deleted contents back:
http://blog4mark.blogspot.com/2012/12/photo-recovery-after-delete.html
In fact, this freeware has ever successfully saved all the inaccessible data of my friend off from his camera. So, I believe it can also work successfully on your camera memory card, too.
Simply read more information of this freeware here:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
Step4. Save and back up all the restored photos on a different memory card or drive in case of data recovery failure.
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on May 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
2134
Points
15
Do not worry, it's possible to recover deleted photos from canon digital camera, take a look at this blog post that helped me before
Recover deleted photos from canon digital camera
hope this helps.
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 59 Answers
  • Posted on Mar 09, 2012
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
59
Questions
0
Helped
93967
Points
71
Hi,redds! You can recover your lost images from your Canon A560 digital camera with a Canon Photo Recovery program: http://www.canon-photo-recovery.com/ Best wishes!
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Dec 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
2616
Points
19
You should try photo recovery software to rescue the lost images, here are some you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your images are recovered, do not attempt to save more files to the memory card in case the original files(your images) are overwritten.
I lost my install disc for Canon PowerShot A560 camera
You don't need to install your camera in order to use it.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1helpful
Can see image via LCD but while do load to PC, its shown no image
1.May be files are hidden
2.if photoes in camera try to transfer it to the Memory card and then connect it to the pc
if helps rate me
1helpful
LCD screen not showing picture to take.
Could be ccd problem. These were common with this type of Canon camera. Download Canon pdf file re these faults.
Powershot A560 overheating
change your batteries our contact your customer care
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Transfer image to computer
Send pictures through email
download the pictures onto your computer then attach them to the email, some digital images are too big to send through to some email accounts so i suggest you either resize them before sending them or zip them.
I hope this helps
Deleting photos from camera
For the Powershot A560:
1. Turn on the camera in playback mode.
2. Select a picture using the right or left arrow buttons on the back of the camera.
3. Press the button with an icon of a trash can.
4. A menu comes up:
Erase? Erase Cancel
5. Select "Erase", then press "FUNC. SET."
Page 18 of the Powershot A560 basic manual also explains how to erase individual images.
Page 73 of the advanced manual explains how to erase all images.
You can download both user guides here.
Jul 20, 2008 • Cameras
Lost system disc
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Image is blown out
Check the "Exposure Compensation" or something similar. If it is low, will make the photos look darker. So set that to "0" if it isn't already.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
