The reason there is an error message on your memory card is because the memory card might have been damaged or probably not inserted properly.
To find out if the memory card is damaged, try to use the memory card in other devices that supports the memory card to see if it works. If it works on other devices, then the problem if from the card reader that is in the camera, and if it does not work, then the memory card is faulty. And the only solution is to replace the memory card.
To test the slot in the camera, try a tested okay memory card on it, if it does not work then the slot is faulty and to solve this problem, i will strongly advice you take the camera to a camera repair guy to clean the slot for you.
Goodluck
SOURCE: memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
SOURCE: Memory card locked
hi this is to tdiddy your right i was having all the same problems and couldnt understand it however did what you said and it worked!! on mine it was a tiny grey button at the side which moved up and down. couldnt believe it was that little thing causing all the trouble.
SOURCE: Canon powershot sd750 memory card files were
Did you forget to use the "safely remove hardware" function when you removed the card from the computer?
SOURCE: Anytime I inserted memory card
Hello
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off.
2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
Kind
regards
Andrea
SOURCE: I have a 4GB SD HC card that works well in my
The S2 IS uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. While you can use SDHC cards with the SD750, you will have to use SD cards, 2GB and smaller, with the S2 IS.
