There may be damage to the balance ring which is situated on top of the basket. This hollow ring is partially filled with fluid which will move to compensate for an unbalanced load. Normally this model would be able to handle up to 5 -6lbs of unbalanced load on one side without significant movement. If the fluid has leaked out it would have a hard time with a slight unbalance. Without some disassembly, it will be difficult to tell. A couple of quick things to look for would be: If the ring still has fluid, you might be able to hear a slight sloshing sound when you move the tub back and forth with your hand. If it has leaked you might see clear droplets that have a greasy feel between you fingers and do not evaporate like water would. That is if it has not been washed away during use.
SOURCE: Frigidaire Gallery Model FWT449GF Tub issue
level and balance is very important for all machines. make sure it is firmly seated on floor and shipping bolts pins and brackets are removed (some have brackets inside.) the machine should be able to evenly distribute the load. finally the shock absorbers could be bad. (seems rare on frigidaire)
SOURCE: spin cycle noise
Most likely, your pulley is coming off, my pulley mad that knocking sound for a year before the belt fell off and I had to address it. see the previous post on how to fix this issue.
SOURCE: GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
SOURCE: GE washer does not agitate or spin
There is a fusable link that is known to blow. The replacement is available. Open the front access panel, Remove the tape from the wires that are taped together near the top of the wiring harness,about 3/4 of the way up. You will see a wire that is covered with shrink wrap (White with Red stripe I think) Cut it out, check for open circuit with an ohm meter. If it is open, (no continuity) Replace it. I used a regular piece of wire as a jumper for testing till I got the new fuse. The fuse kit I got comes with 2 of these fusable links. One is for a spare.
