Question about Sony FD Trinitron KD-34XBR960 34" TV
Sony KD-34xbr960 will not turn on. Standby/Timer LED continually flashes.
  • johntomko Sep 13, 2010
    Rylee,
    The LED actually flashes 7 times over and over again.
    John T.
  • johntomko Oct 07, 2010
    Rylee,
    The DZ Board from your link was back ordered 3 times. I did more research and found that the 18 pin IC chips on the board are normally what goes bad. I ordered the chips and installed them along with the chip sockets. Sockets were not originally installed. After I powered the TV up, I heard a noise (pop) that I hadn't heard before. I then realized I forgot to reconnect the 4 bridges from the DZ board to the board next to it. I unplugged the the TV, reconnected the bridges and now the TV sounds like it wants to come on, the standby/timer led flashes slow 3 times (not fast like the 7 times flash), I hear a click, and the TV shuts off. I may have damaged something by not reconnecting the bridges before power up. Any suggestions? Is it still the DZ board? Any other sight to buy the DZ board from?
    Thanks,
    John T.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If its flashing continuously and you are unable to count the no# of blinks then the issue is with the bulb going bad and should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
  • Rylee Smith
    Rylee Smith Sep 13, 2010
    Thanks for your reply John, 7 blink in your Sony KD-34XBR960 is caused by the DZ Board going bad and to resolve this issue you'll have to replace it. You can buy the parts from this link. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Anonymous
SOURCE:
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Kd-34xbr960 doesnt come on
Count the number of blinks of standby light at one time after switch ON. Count it once more and make sure that the out is correct. These blinks are fault indications. Check this link to get more details about the blinking codes to Sony Trinitron TVs. Details are there. You can locate the faulty section by these blinkings. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 11, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron tv is not turning on. It has turned on a couple of times, but the standby light on the front is blinking. WHat's wrong?
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sony Televison & Video
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
I have a Sony KD-34XBR960 that sound like it is
phillips has the same problem but if your tv actually turns on it could be a short or just a fuse sonys a better tv than phillips should be an easy fix call a repir guy going price for that problem is 75.00 dont pay any more than that. the economy is bad everyone needs the work be smart. make sure if you say yes to the work that the repair guy will waive the consultaion cost of usually 35 to 75 dollars, if you chose to have the work done.
Jun 02, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
My standby light is blinking and the screen wont come on. is there anyway to fix it?
This is from the Sony support site...
URL to page
"The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center."
Jan 24, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Sony FD Trinitron KD-34XBR960 34" TV Logo
556 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
