Contributor
- Posted on Sep 14, 2010
Re: I'm trying to connect my Wii to the internet with the...
Connecting directly to a modem:
- Power off the Wii. Connect the official Nintendo Wii LAN
adapter to the Wii, and insert a working ethernet cable into the
official Nintendo Wii LAN Adapter.
- Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
- Power cycle your modem. To do this, unplug the power from
your modem and let it rest for 20 seconds. Plug the power back in.
Connect the Ethernet cable from your Wii console to the Ethernet port on
your modem.
- If the connection test fails, try a "Manual Setup" with the Wii console (how
to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
- On your PC, click "Start" and then "Run."
- Type "CMD" into the field that appears to open a new window.
- Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings,
including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the
Wii console's internet connection.
- If you are still unable to connect and you are using
broadband Internet, then your ISP likely uses PPPoE to establish a
connection to their network. The Wii is not compatible with PPPoE.
Contact your ISP for more assistance
