LG WD-14124RD Front Load Washer / Dryer Logo
Posted on Sep 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The cl lock is on and won't oppen - LG WD-14124RD Front Load Washer / Dryer
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 12, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5036409
Points
35540
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
2answers
Bosch dishwasher start with CL code
That is just saying the Child Lock (CL) has been activated.
Deactivate the child lock ' Bosch
Bosch Home https://www.bosch-home.com > ... > Get support
1. Press and hold the start button for three to five seconds ... When the child lock is activated, there will be a message "CL" in the display and all the washing ...
Bosch dishwasher child lock problem
Bosch-home.co.uk https://www.bosch-home.co.uk > ... > Dishwashers
Hold down the lock button for three to five seconds. You should hear an audible beep and/or see the symbol disappear. The child lock is now deactivated.
What does CL mean on a dishwasher? And how do I fix it?
Quora https://www.quora.com > What-does-CL-mean-on-a-dish...
This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ...
9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
How to turn off the CL on the display of a bosch dishwashe...
JustAnswer https://www.justanswer.com > Appliance Repair
Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone.
1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your
..https://www.youtube.com/watch?v=Xr4DBwACUW4
Kenmore Elite Dryer Error Code CL
Child Lock
The CL indicates the unit is in a Control Lock mode. This is sometimes referred to as child lock and is meant to prevent accidental option or cycle changes while the dryer is running. ... This is the keypad that turns the control lock feature on or off by pressing and holding the switch.Nov. 28, 2014
How do you clear the CL code on a Kenmore Elite dryer?<br ...
www.shopyourway.com > questions
VIDEOS and Fixes
https://www.google.com/search?q=Kenmore+Elite+Dryer+Error+Code+CL
Need to clear cl button
It is indicating that the CL or CHILD LOCK feature has been turned ON and is active. LG washer code cl error. TO TURN OFF CL CODE ON NEWER LG FRONT LOAD WASHERS: To TURN OFF CHILD LOCK on your LG washer, press and hold theCHILD LOCK button for 3 to 5 seconds.
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
CL-200 lid won't lock into place because it's to tight.
Gasket in lid is swollen from chlorine gas over time, check to see if you can tuck back in and lubricate it with a silicone grease. if to swollen, replace gasket.
Won't start CL flashes
Hi catherine739,
The CL you are getting means "Child Lock".
Please do the following:
- On the Facial Panel (Where the buttons are located), look for 2 buttons marked together with a line, it should also have a face of a child somewhere on that line.
- Press both these buttons together for 3 - 5 seconds, this should reset the Child Lock.
Kind Regards :-)
Jedemeyer1
*If you found this solution helpful, please rate it
Jun 09, 2011 • Dishwashers
Lock is stuck and the door won't close. The lights are flashing
Disconect fuse at breaker pannel. Then with a plastic dowel or blade trip the lock to oppen. Then it will operate normally. What happened is the lockig mechanisim shut down with the door oppen. Vitally
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
