SOURCE: connecting a samsung dvd-vr to TV with cable & rf modulator
it doesnt have a coaxial but it definitely has an Audio video connector port, what you do is buy one, its a 3 piece cable one is yellow for video, and the other two is red and white for audio, if your using flat panel TV it will definetely have that port.
SOURCE: Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
SOURCE: Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Testimonial: "Thanks for the info! Very helpful!"
SOURCE: Moved our Samsung lcd tv
Hello
Just retune the TV with coaxial cable connected, make it auto tune as per its manual says. Make sure to note whether the coaxial cable end connections are firm. The problem now you faces is due to AGC [automatic gain control]. It must be retifed as you autotune the tv. Please wait till all the channels have been tuned and stored in its memory and displays the first channel received. Make a keen look at the coadial cable connections and make sure that it has no break inside at all. OK.
