It's most likely that the filters in your dishwasher are blocked, the best way to clean them is to remove the filters from the bottom of the dishwasher, place them in the racks and run through the hottest wash cycle. It also helps to have a dishwasher cleaner inside the machine at the same time, these are available from most places that sell the dishwasher powder.
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
SOURCE: Dishwasher will not drain
Hello Tom,
Glad that you were able to find something out of place in the check valve ( like the gasket) which in turn was restricting the ball in that check valve from being in the right position. I'd be willing to bet that your problem is solved..
Regards,
Rick
SOURCE: Whirlpool dishwasher 2966 draining failure
take the airgap apart. located on top of sink. clean out and reassemble.
SOURCE: dishwasher washes dishes but does not drain...I
http://www.associatedcontent.com/article/818791/got_a_dishwasher_that_wont_drain_heres.html
Here is a list of possible reasons and if you check responses, you will see that it solves the issue for most people.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
