SOURCE: Error condition ribbon out in ZM400
In the printer setting-
Change the Print Method from - "Tharmal Transfer to Direct Thermal" and save it permanently
SOURCE: como cambiar ip de zebra zm400 desde el panel
you need to connect with some network to the ip adress coming on the setings, if you dont connect with network, that function not apper.
If connect, you be aple to change to IP estactic and the Gateway and the subnet mask.
Dont forget to save.
SOURCE: zm400 print a part of a label. Hello, my Zebra
What part, rigth site or bottom site?
check the lengt and the with from the driver and print the testpage (have to print on full label)
if is one of the sides, try to give more pressure to that side on the printhead.
SOURCE: Printing and counting problem with Zebra
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
