Nikon N50 35mm SLR Camera Logo
Posted on Sep 09, 2010
When I load my film the display says err - Nikon N50 35mm SLR Camera
1 Related Answer
Anonymous
  • Posted on Nov 20, 2008
SOURCE: 'Err' & 'E"
Is the film loaded correctly? Have you tried reloading it? Also is it flashing DX too? That would mean the film speed is not DX coded so you need to set the film speed manually.
What does err with flashing film picture mean
It means either your film has reached the end, the film is jammed and cannot advance or the film is improperly loaded. The film leader may have slipped from the sprocket or broken,
2answers
ISO DX ERR
What speed film? Does the roll have the DX markings (the black-and-silver rectangles)? If it doesn't, what happens if you set the film speed manually?
1helpful
The new roll of film winds into the right spool upon closing back cover // brand new batteries displays 1/2 and ERR appears on led panel
Is the ERR blinking, and is there an additional blinking E on the display? If so, the film is not loaded properly.
The film is supposed to advance all the way to the take-up spool upon loading. The camera then "rewinds" one frame at a time as you take pictures. This way the camera knows exactly how many shots are left on the roll. Also, if the back is accidentally opened, the shots already taken are already in the can and won't be ruined.
If you need a manual, you may download a copy here.
Try cleaning the battery contacts and see whether the battery reads full with no film in the camera.
If problems persists, feel free to reply to this post and give any additional details.
1helpful
I bought a second hand Mamiya 645 Af but as soon as I load a film it shows a error message ERR 01 .... what is that ?
From the manual:
"If the error display is not canceled when the shutter release button is pressed again, insert the Dark slide, half-press the shutter release button while pressing the roll film holder's manual film advance button to wind up the film, then contact your nearest Mamiya agent or service center."
If you need a manual, you can download one from
http://butkus.org/chinon/mamiya/mamiya_645af/mamiya_645af.htm
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
'Err' & 'E"
1helpful
2answers
Error message on camera
I had the same problem, what I did was set ISO to manual,and still got the Err,but I took a shot and the film advanced and it seems to be ok now.
6answers
FILM REVERSAL
does anybody know a freakin solution????
Film won't adanvce
Needs new batteries, or the film isn't loaded properly. Check the battery area for rust too and clean the contacts gently with a pencil eraser.
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
