My phone nokia 1202-2 imei 356048039377774 my code?
My phone nokia 1202 imei 353195/03/657049/8 code 0562271 i for get my code p
Normal Reset
You can use the *#7780# sequence. It will restore ini files from ROM
having entire data of your mobile phone (themes, 3rd party applications,
video, photos, and music files)
Deep Reset
You can use *#7370# sequence. That will properly formats the phone
memory. Default files are destroyed and rewritten. One thing should be
considered here that the data found on memory card will not be altered
OR
There are so many ways to get access on your phone.You can open it with
the help of ways, sometimes it can be opened manually and one of the
method through the software to reset it . The users commonly use the
software utility to unlock or reset the phone. It's depends on you that
what you want to choose to reset your code.One of the popular software
to reset your Nokia code, Master Security Code which can be used
to unlock or reset your current situation and then you can easily access
your pone after assigning a new one code..
SOURCE: I cannot unlock security code of my nokia 1202-2
i surfed the inet...no one knows how to unlock Nokia 1202-02 (RH-112)
Master code is found for my IMEI, but it does not work ....
#pw+xxxxxxxxx+1#
f sake
SOURCE: how to unlock nokia 1202-2 SECURITY CODE
I forgot my nokia 1202 security code,which imei no is 355240/03/749662/0
6622004514 This should be your master code. You should be able to unlock with this. Good Luck
