Samsung YP-U3 driver
REALLY REALLY REALLY REALLY WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! yes yes yes yes!!!!!!!!
I solved the problem after i was really crazy of anger with samsung company, but i found this solution in one forum.Thank you
very much, anonymous Guest!!!!!
Hi All,
I just solved the problem after many attempts!
It works for me, and i hope it works for you too~First install media player 10!
When I plug in my YP-U3 player, the computer says it needs to search for a driver, then i let it search it online. But it normally
won't search the driver on the internet. Then, it will give a prompt to ask if you want to find a solution or search the driver from
the PC. Choose the second option, searching from the PC. Then change the directory to C: (Which is the most crucial part).
After a while, the driver should be found and a warning message will appear. Forget about the warning, choose install the
hardware anyway, player should be recognized by then.
(I have had windows media player 11(10 also works), direct X 9...etc. before installing the driver)
