Mine's doing the same thing, and no there is no error code indication. Just simply no green light when trying to take a photo. Nothing at all.Mine's doing the same thing, and no there is no error code indication. Just simply no green light when trying to take a photo. Nothing at all.
You can't post conmments that contain an email address.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
TRANSFERRING PHOTOS TO COMPUTER If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device, you can then open the folder on the memory card andcopy the photos to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery and Picasa.
Apparently, you have pics on the camera's internal memory. Your card won't work until those pics are gone. Here's how...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work.
There are some digital photo recovery companies that can retrieve your pics. Depending on how many pics are on the card and how badly damaged it is, they charge between $100 to $500 dollars.
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
First of all, recover lost files from memory card 1. Do not save any new file to memory card. 2. Connect memory card to computer. You should see memory card shown as a drive letter (like H:) in My Computer. 3. Download best photo recovery software from here this asoftech photo recovery program help me before, works quite well and it's easy to use 4. Install and open asoftech photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your photos.
After you get back your photos, you can format the memory card to fix the problem.
