The car seat should go in with baby facing you or you could try this website.. Hope this helps.. www.gracobaby.com/customerservice/productinstructions/...
Safety 1st do not produce adaptors for a Graco carseat to be fitted to the DuoDeal Tandem. This stroller chassis is not designed to be used with a carseat.
Recline the stroller seat. There are probably little plastic handles on each side of the stroller seat that you push in while you stand behind the stroller, to recline that seat. Then, you put the carrier into the stroller, facing the back of the stroller. The little notches in the bottom of the carseat fit right onto the edge of the stroller tray. You can test that you've done it right by pulling upward on the carseat. It should not come up and out of the stroller unless you pull the red handle on the back of the carseat as you life the handle of the carrier. I hope this helps!
