Hitachi 50UX57B 50" Rear Projection Television Logo
Posted on May 14, 2008
Tint on television stays a greenish color.
My tv. screen turned blue with some static noise. The tv. shut off and I had to unplug the tv. and wait for some time and plug it in for the tv. to come back on. Now the screen has a yellowish or green color to it and I cannot get the picture adjusted properly.
Emery Miller
Level 1:
Problem Solver:
  • Contributor 26 Answers
  • Posted on May 29, 2008
Emery Miller
Contributor
Level 1:
Problem Solver:
Answers
26
Questions
0
Helped
2922
Points
44
Tubes are probably dirty. Very expensive fix. Unless it has a warranty or is recently new, look for a local cheap one or one with a smashed screen of the same size. Easy to change the screens out and is very cost effective.
Greenish tint
Might try the color tones buttons on T.V. up or down.
My samsung hl61a750a1fxza only has blue and green picture only, why?
Your red tube is dead. There are three primary color tubes that create all the colors. A new tube can cost $250 plus installation and then you will have an old, obsolete TV with one new tube. A new 46 inch TV is less than $400 these days.
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
Panasonic 56" projection color problems
there are so many technologies for the projection tv's ever one has their own caracteristic faults with out you mention the technoligy used on your tv will be deficult to help you but assuming is a lcd projection you must have a problem with the optical block the repair will be expesive if you do not have a manufactuer warranty for it
I have a KP-65WV700 and the screen looks a lil to green
OK, I'm the guy that was having the same problem, but had a blue tint to the screen. I also had blue lines running across the screen, and when I followed the steps below that were posted by another user not only did the lines disappear, but the blue haze vanished as well. My tv looks like it's new again, so you may want to try this:
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I have fixed this several times on my KP 65WV700
As Slinteriors posted if it is a thin curved line you need to adjust the screen control, it's sorta like a brightness for each color, and if one color is too high it will produce a thin curved line.
The best way I have found to get to the controls is by removing the lower grey speaker cover front the front of the TV. There are 6 screws if i remember, 3 on each side. Then it snaps off, seems like its going to break but you have to pop it off pretty good.
Once its loose you have to remove a cardboard like cover plate in the center that will give you access to the small controller board.
Now be very careful while experimenting on which knob controls which colors. Turn them very slow, if you turn to fast you will cause your TV to shut down. If this happens, turn the adjustment back to original spot and turn TV back on and take it slow.
Adjust the correct color until the line just goes away. Its easiest to do this with a black screen.
3helpful
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
1helpful
2answers
Color problems
I have the same problem... today I got a digital satelite tech come out and hooked a HD digital reciever to the tv and now I have the greenish/yellowish/blue tint hhhmmmmmmm?
Big vertical tinted stripe on screen
Need more information:
Can you isolate which color is causing the banding?
Is there something ON the lense itself?
Is the projection mirror broken or bent?
S
Tv turns off, volume adjusts incrementally then shuts off, screen is tinted blue
there is a defecton the small signal panel. most of the time caused by power surge..john
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
