Your LG washing machine’s motor is controlled by the main circuit
board. This is the brain of your washing machine. Depending on the
selected program and which cycle is currently running, the PCB will tell
the motor which speed to run at and which direction to turn. The Hall
Effect sensor on the main circuit board is fed operational feedback from
the motor. If there is any difference between what the motor should be
doing and what it is actually doing – the appliance will stop operating
and display an “LE” error.
For example: if the main circuit board tells the motor to rotate
clockwise at a certain speed and the motor doesn’t start, the monitoring
sensor will relay this inactivity to the main PCB and a “LE” error will
persist. The same error would be displayed if the motor rotates in the
wrong direction or runs at the wrong speed. It should be evident there
are many faults that could produce the “LE” error code. Failure of one
of the major components or a fault in the monitoring and feedback loop,
could all lead to this problem. It is true however, some faults occur
more regularly than others. Test for the most common causes of failure,
eliminate them, and move on to more unlikely faults.
Many causes for the “LE” error are thought to stem from LG’s
manufacturing process. Many customers found the wiring damaged or
completely severed in their washing machine’s motor drive and feedback
loop. If the wires were installed too close to a moving part, they may
be vulnerable to mechanical wear once the machine starts to operate. A
washing machine vibrates a lot during a spinning cycle, so it is
conceivable wires could be damaged in this way. Check the cables feeding
the motor for any obvious signs of damage. If you cannot see any
problem, disconnect those wires and check for conductivity with a
multi-meter. There should be almost no resistance detected in the wire.
If you find a damaged wire, replace it and ensure the new wire is
well out of the way of any moving parts. If the wire is faultless you
will have to move on and continue fault finding. Try and turn the
motor’s rotor by hand, if there is any real friction or if the rotor is
seized – you will have to replace the motor. Faultless wiring and a
washing machine motor - with the existence of an “LE” error code,
indicates a fault in the main system board. It should be noted though;
this is unlikely to be the cause of the problem. Almost all “LE” errors
indicate faulty wiring - so ensure you have properly checked this before
installing a new PCB.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
