Water gets really hot everything looks okay when i took it apart but it still has the problem that it will not pull the hot water out through the grounds and to get me a nice cup of joe
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
What seems to be the problem when i pour water in where the water is soppose to go i wait for the water to come down and it doesn/t it does get hot, but no water comes out at all
