A defrost water drain pan should located under the unit on top the coils. Or in the outside in back mounted on top of compresser
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: Bottom of Maytag Freezer Ices Up
I just had the Maytag repair man out and he wanted to replace to parts after defrosting the freezer. Over $300. He did not have the parts with him. Soooo... I am now in the process of using a hair dryer, even tough it is 107 here today. Ice was totally covering the coils under the back panel in the freezer. Easy to take out. Just remove the shelves and you will see it. If you don't totally get all the ice out it will build up even faster. He claims this will give us 2 weeks or so while the parts on on order. I now have all the ice I can see removed, I just hope it is out of the tube above the coils. I have all my food, lots of good steaks, I want to put back in the freezer. The original problem seemed to be the refrigerator was not working but the freezer seemed to be. Well, it just faked me out because it was just a fan or ?? I heard in the freezer. Wish me luck...MJ
SOURCE: How do I clean my drain pan on my side by side refrigerator it smells
Hi. Thanks For The Question. Pull Fridge Away From THe Wall. Remove Back Panel Clean All Coils. Remove Drip Pan. Clean. Thanks The Appliance Doc
SOURCE: terrible smell coming from bottom of unit
There Should Be A Grill On The Front Bottom Below The Door. Remove That And It Should Come Out Of The Right Side.
SOURCE: ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
SOURCE: Water colecting on floor of freezer in
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
