Hello Rick,
Welcome to
FixYa.
There are 2 internal fuses for the
Asko washer, on the 20004 model they are located at the back next to the power cord...
i.e.
To remove and check the fuses you`ll need a flat/slotted screwdriver and place it in the slot of the fuse holder and turn them left 1/4 turn and pull out.
**The above is an image for removing the dryer fuse, but the same procedure applies**
Once removed this is what you should see...
I would also suggest removing the top of the washer to visually inspect the condition of the wires as a poor connection can cause the fuses to blow.
i.e.
The replacement part is a 240v 15 amp slow blow fuse. part number will be as listed below and it is a complete kit available at "repairclinic.com"
# 1460992
Hope that answers your question or better yet solves the problem altogether.
Thanks for choosing
FixYa and good luck. Please take a moment to rate the info provided and a short testimony if you will its warranted.
Regards,
Macmarkus :)
