Microwave Ovens Logo
Posted on May 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the F2 error code and bought the switch membrane. Now I have the panel off but it appears the staneless steel cover is glued to the plastic inner panel and I did not want to pry it off and damage it. How do I get the outside steel panel off so I can replace the membrane?
William Miller
Level 3:
  • KitchenAid Master 9,179 Answers
  • Posted on May 27, 2008
William Miller
KitchenAid Master
Level 3:
Answers
9179
Questions
Helped
4481495
Points
21747
It would help for me to know your model number, but I'll tell you what I know generally.
Often the metal cover is held in place on the plastic control panel frame by several bent metal tabs which are visible from the rear side of the plastic frame.
You may have to remove your circuit board from the frame to see them and bend them straight so the metal cover can be removed.
The drawing below should clarify this.
We're happy to help and we appreciate your thoughtful rating of our answer.
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
My Samsung SMH8165ST Stainless Steel 1600 Watts Microwave Oven Problems
This indicates a system error, the keypad has a short in the membrane, the keypad control board will need to be replaced.
Whirlpool ADG 4956 - problem F2
Hi, here is the answer for f2 "F2 - error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
5helpful
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
5helpful
F2 Error
F2 is a membrane switch error.
1. Unplug microwave oven or disconnect power.
2. Replace membrane switch.
3. If problem persists, replace electronic control.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
The answer to your question is YES. I would venture to say the PART is - but not the labor. You would need to read your warranty to confirm.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
My microwave start button doesn't push in to start my microwave
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
It's most likely that the keypad is worn out or possibly you have a flaky door switch.
We have full details, critical safety, disassembly, and troubleshooting info (as well as door switch testing info) at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually order Samsung parts (either the keypad / membrane switch or control panel with keypad) from http://www.samsungparts.com but that model number is not showing up, so you may have to call or e-mail them through their site.
7helpful
2answers
Kitchen aid microwave oven not working.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
