Question about Sewing Machines
The underneath stitches are loose - Sewing Machines
    New Friend:
  • 3 Answers
When you see loose stitches underneath your sewing, it usually means that the top tension needs tightening. Write down where your tension disk is before you turn to a higher value, then sew. Keep doing the above until you reach the correct top tension. The reverse of this would be loose stitches on top which means the bobbin needs to have the tension screw increased, little at a time, about 1/8 ". Sew and repeat until the stitches are equal.
Posted on Sep 08, 2010
6ya staff
SOURCE:
Disney embroidary pe18od loose stitches under work what am i doing wrong
Use a brand new needle that is best suited for the thread weight and type of fabric you are stitching.
All About Needles
Be sure that you ALWAYS RAISE the presser foot when threading the upper thread. This releases the tension disk so the thread will seat properly. Also, if it continues to have loose stitches underneath, tighten the upper tension.
Oct 18, 2016 | Sewing Machines
Loose stitching underneath
try adjusting the top thread tension and see if that help the loose stitches underneath.
also try changing the needle
and clean under the needle plate and in the bobbin area
Aug 21, 2013 | White Sewing 2037 Mechanical Sewing...
Sews small stitches on the top and loose stitches underneath from the bobbin.
change needle
change your stitch length dial to a number higher like if it on 3 change it to 4 or 5
change the tension to 3 or 4
clean under the needle plate where the feed dog is for lint
clean the bobbin area for lint or loose threads
rethread the machine
Nov 22, 2010 | Baby Lock Ellure
Having rethread the spool it is now stitching but the underneath stitch is still loose
Did you thread with the presser foot up?
This opens the tension control so the thread can enter.
When the foot is then lowered to begin sewing, the thread will have the correct amount of resistance to form a proper stitch with the bobbin thread.
May 08, 2010 | Singer 5070 Mechanical Sewing Machine
Sir I am owning a Janome Memory Craft 10001 but recently it's not working properly in ordinary sewing mode the top side of the fabric the stitch looks okay but underneath it is loose and while embroidering...
Usually If the underneath is loose it is the top tension that is the problem. If it is the top stitching that is loose it is the bottom tension. Hope this helps.
Jan 24, 2010 | Sewing Machines
When making a straight stitch or Zigzag stitch, makes loops underneath the fabric This is for a Singer sewing machine model 5817c
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Feb 21, 2009 | Singer 5050 Mechanical Sewing Machine
TOP STITCH IS FINE BUT WHEN I TURN FABRIC OVER THE UNDERNEATH LINE OF STITCHING IS LOOSE . WHAT CAN DO TO REMEDY THIS PROB .
Sounds like your upper thread tension is too loose. Try tightening the tension on the top thread, but first, make sure the machine is threaded correctly through the tension disks.
Aug 29, 2008 | Bernina 1008
Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Jun 27, 2008 | Juki TL-98Q
Won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Jun 25, 2008 | Janome D'cor Excel 5018
Sewing Machines Logo
426 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
