Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
I have just purchased a verbatim micro usb drive 4gb, I got it home and plugged it in, tried to copy a file to it, and it said that it is write protected. Please help
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
Contact Verbatim for a solution, these USB flash drives have lifetime warranties!
Posted on Oct 25, 2013
6ya staff
SOURCE:
Anonymous
  • 27 Answers
SOURCE: Verbatim flash drive
mabye its full or the files corupt
Posted on Dec 03, 2007
Anonymous
SOURCE: How do I turn off the write protect on the verbatim 4gb flash drive?
I solved write protection on my Verbatim store 'n' go 1 GB by this program "HT203 Handy Steno 2.0 Repair Tool" which format FLASH DISK from http://emea.apacer.com/en/support/downloads.asp . I know its different manufacturer but its working.
Posted on May 11, 2008
Anonymous
SOURCE: Verbatim Thumb Drive problem
Download the following, I had the same problem and then this worked. Version 1.2.0.4
http://www.verbatim.com/support/support-article.cfm?support_id=858682BD-1422-1392-A8E8CBC9CA6CFE95&supportType=Download
Posted on Jul 22, 2008
Anonymous
SOURCE: I am having Jetflash v10 16 gb model 'Transcend' USB Flash Drive.
Try formatting the drive using NTFS and re -copy your stuffs again. If it fails to copy as you want, then delete the partition and format it again .
Posted on Mar 26, 2009
Anonymous
  • 23 Answers
SOURCE: verbatim 4gb flash drive write protected error
your problem can not be solved, u can only buy a new one
Posted on Sep 04, 2009
I plugged my cruzer into my home computer to get some music files. I copied them on, then disconnected the drive from my home computer. I went to put them onto my mac, and when I copied them over, i...
I assume by you saying you didn't get any memory back that it still has the files on them or it looks that way. Now when you copied them did you just drag them over? When you go back to the thumb driver or the files still on there? usually when you copy all you are doing is just that copying you are not removing the files from the original source. If you copy them and then you would like to delete them just access the thumb drive again and then delete the files and you should get the space back.
thank you,
Lee
Aug 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Purchase 5 new verbatim 4gb when i plug it into pc the system found new hardware and installed . then it allow me to used two of the drive. when i plug it in the pc a msg appear, u need to format the disk...
You have to format the drives. If you put data on the drives using computer 'a' whos OS is MacOS and then you put the same Drive into computer 'b' which has windows, it may not recognise the file system/structure.
Nov 23, 2017 | Verbatim Store 'n' Go 4 GB USB 2.0 Flash...
I have a verbatim 4gb micro with a write protect error. I cannot delete the files, add more files or format the stick. Regards Mano
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Jan 06, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
I'm Windows XP... I can copy many files to the Verbatim. But when I try to copy a 1GB+ file, the copy craps out. I Googled and found some Microsoft problem when copying 1GB+ files to external drives, but...
The usual limit is exactly 2GB, not 1GB.
It's a limitation of the file-system used for the directory of the disk-drive, when formatted according to the 'FAT32' specifications.
So, copy all the files currently on the Verbatim to your disk-drive.
Then, "reformat" the external (not the "internal") disk-drive, using the 'NTFS' file-system. This file-system has a maximum-file-size limitation for one file that is _much_ larger than the capacity of your Verbatim.
Then, copy all the "saved" files back onto the Verbatim.
Finally, copy your "large" files onto the Verbatim.
Sep 30, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Trying to up date drivers on drive to windows 7
You really shouldn't need any software to View and Cut, Copy, Paste files to your 4GB Flash Drive. You can usually use these Flash Drives just as you would a DVD, CD, or Disk. When you first plug in your 4GB drive, it should be detected and should automatically install the "Drivers" and then, it should show up as a "Drive" in "My Computer". If this doesn't happen then you have "Other" problems. Check that the drive is OK by trying it in another machine.
Jan 20, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
May 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Plz Help Me
I'm not an expert with PCs, but I have a windows 98 Operating system and have been able to use all sorts of flash drives. Everytime I buy a new one, I just plug it into the USB port and in a short time it recognizes NEW HARDWARE and loads the driver. I've used LEXAR 2GB,SANDISK 4GB, VERBATIM 2GB, and recently a ATIVA 4GB
Apr 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My flash drive verbatim 8 gb store and go is not recognized
I looked into similar problems and if this works ill let you knw i downloaded Paragon Pation Manager and i plan to use this to create a 8gb partion on my flash drive i dont know if this will work but ill get back to you
Nov 05, 2008 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
158 people viewed this question
Top Verbatim Computers & Internet Experts
ChinthakaJ
ChinthakaJ
gggg
Duncan Mutch
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
