Good Day, I have a FUJITSU 3500 and I loaded windows xp on it.
I got everything to work except the pen,
I did load the drivers for the pin, its called cic penx but when i reboot the tablet it asks me to initialize the tablet.
I dont know how to do that,
Please help
[email protected]
First install fujitsu's driver and THEN the CiC drivers, just look in your device manager and search for Unknown Dvice or CIC PenX Filter Driver then install the Fujistu driver when thats done install the CIC drivers. Please note that the driver has some incompatibles in Windows XP Sp2/3 (the callibration tool does not work and with bootup i will give you an error(not critical))
Good Luck :)
"OS" are: XP, Vista, and Windows 7
Select the [Drivers] you need from the "List."
"Download the Drivers."
!"Take a moment to rate the help."
Thanks paul7of9
Click here: http://support.fujitsupc.com/CS/Portal/driverdownload.do
Hi thanks,
I did install xp with SP2,
Do you think I must download it and install it separate?
will do will feed back
thank you
exactly same problem but i've loaded xp sp3
same problem, different operating system. Windows 2000 asking for initialization. When it boots, first thing it says is pen initialized and mouse initialized. By the time I get to windows....no pen! I feel this is somehow related to the mouse function but how do you get the system to plug the driver for the pen into the mouse hardware display? If the pen showed up there then I know the thing would work.
I had to reset tablet and did the setup wizard option at reboot. so when it come on it asks about language then wifi setup then time zone then at end of setup it says unfortunately.com.wmt.setupwizard has stopped. then takes me right back to the language setup. over in over again I cant get out of the setup wizard please help
