LG 47LH40 47 in. LCD HDTV Logo
Posted on Sep 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a cracked LCD on my Lg 47lh40 - LG 47LH40 47 in. LCD HDTV
Anonymous
Level 3:
  • Master 458 Answers
  • Posted on Sep 04, 2010
Anonymous
Master
Level 3:
Answers
458
Questions
0
Helped
217351
Points
1225
Need replaced LCD panel
Manufacturer LGE Part Number EAJ60659701 Description LCD,MODULE-TFT
1helpful
Lg 47lh40
Check its connection between LCD pane and T'con board for any loose contact.
3helpful
Our brand new LG TV loses brightness whilst you are watching a programme.
Check to make sure that eco mode is turned off. It will sense the ambient lighting and if it is bright, the TV will be bright so if you are seeing the brightness change...check that setting first.
1helpful
I just bought an open box lg 47lh40. The TV remains on for about 15 minutes then begins to turn itself off and on. Any suggestions?
This is a circuit board issue. Your going to have to call LG and find someplace to have it fixed under warranty. Open box items cannot be returned so LG will give you someplace around your area to bring it for the repair.
9helpful
2answers
My LG 47LH40 does not power on light at the bottom is off. What can I do it was bought last November
I just came across this problem. I called in, and they said there was a power switch right beneath the light on the bottom right edge of the tv. So I decided to look down there and it was switched to off. Switched to on and that was the problem. I didn't even know there was a button there, but apparently one of my friends turned it off while he was drunk.
1helpful
I have set my LG 47LH4000 to trumotion 100hz but when you press the ok button when watching it says 1080i 50hz should be 1080p
All TV signals, including SKY, are transmitted at 1080i and 50hz. The only sources for 1080p are Blu Ray, XBox or PS3
Tv will not change at all, nothing works, will only power on, no volume control no menu not nothing help!
Call your LG dealer to arrange a service engineer to update the current software on the TV & to re-set the system, this should remedy the problem.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
