No, I would not advise using Draino in a dishwasher...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
I just went though this problem last night. Follow these steps to minimize the potential work.
First ask if the dishwasher pump is working and if it is then proceed.
1 your dishwasher's dirty water empties into your kitchen drain or garbage disposal. First make sure water is draining properly out of the kitchen sink. If not, then you have found your problem.
2. examine the hose under the sink that leads from the dishwasher to the kitchen sink drain looking for kinks.
3. Assuming neither steps 1 or 2 solve the problem then it is time to get to work on the dishwasher. Get as much water out of the diswasher as possible - a paper cup works great, then Find a You Tube video that shows you how to take apart your dishwasher so you can get to the drain. (I found this video to provide good high-level instructions Clean all filters and examine the food chopper. Then try draining the dishwasher.
4. This is the step that solved my problem. Recover the food chopper and pour about a cup of bleach into the standing water and leave it alone for 30 minutes. If it drains then reassemble the dishwasher and run it at least once to clean out the bleach before adding your dirty dishes. If it doesn't work then you can try pulling out the dishwasher and checking the rest of the hose for blockage OR call a qualified repair person.
SOURCE: Dishwasher drain is clog can I put drano or
Generally there is an access point to unblock the drain in a dishwasher. Use drano with extreme caution.
SOURCE: Dishwasher will not drain. Took drain cover off,
Here is a tip that I wrote to help you troubleshoot this problem..
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
Heatman101
SOURCE: My dishwashers water will not
heatman101
heatman101
Blast water or air through it...
heatman101
