SOURCE: Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
SOURCE: wireless router through Cisco ASA 5505 series
put the one cable to wan which come from internet and you have to connect the pc or any other connection then you connect in the lan
SOURCE: Cisco VPN not working
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
SOURCE: cannot connect to the internet thru D-LINK DI-713P Router
SOURCE: D-Link wireless router & Ubee modem - which router ports
All routers will have a in for you modem, but your outlets wont matter what you use they are normally numbered 1-4 or 1-5. you can use any outlet and your pc will pic it up, they dont have to be in order through the ethernet.
