the amp does work ive tried it with other guitars using the same cable and allthe amp does work ive tried it with other guitars using the same cable and all
You can't post conmments that contain an email address.
There must be a disconnected wire inside the guitar. You can take off the control plate in the back and look at the wires. If the input connector is loose start there.There must be a disconnected wire inside the guitar. You can take off the control plate in the back and look at the wires. If the input connector is loose start there.
Good question, tuners can be simple and some are complicated
a basic automatic guitar tuner you would not have to do anything to the settings, just tune normal on the E string then slowly down tune to D most tuners are a little sensitive, so go slow
and one thing I always do is go lower than the note I'm tuning to then tune up tell it's correct, strings seem to stay in tune better
Hope this helps ?
and if you have time check back on my profile
I will be doing some video tips this weekend
showing tuning, and some basic guitar repairs
thanks for your time
There is something resonating with that note frquency. Often the grille or wiring inside will rattle at certain frequencies. You need a sustained source of these frequencies to find what is causing the noise.
Sounds like the amp (or speaker) blew. Do you have anything else you can plug into the amp to test? If possible use a different cord to preclude that as a cause, too.
Try plugging another sound source into the unit. The buzz MAY be pickup of magnetic fields in your guitar pickup that clobber your notes from the strings. Bad guitar cables are another possibility. By putting clean music from say a CD player into the unit you can find where the source is. If the CD player generates the same noises, then likely you have a failure of filter caps in the amp or other component failures. Also make sure your guitar can't "hear" the amp as feedback can do strange things.
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
