Hotpoint Aquarius WF000 Front Load Washer Logo
Posted on May 11, 2008
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi all
I have a Hotpoint Aquarius WF540 1400 spin which is almost three years old and seems to have suddenly developed a fault. If it is plugged in it basically randomnly turns on, the wash enhance (button 1) and rinse hold (button 3) lights flash slowly, the on/off button flashes quickly and it makes a noise (but does not seem to fill). Any ideas? I have tried having the power off for over 15 mins as the man at Hotpoint said that it might reset itself but that does not work. I also tried to start a normal wash but within the first minute it reverted to doing the above. The man at Hotpoint suggested its probably a programming fault, not sure why it would develop it after three years! Any suggestions/advice as they want to charge a small fortune to come out!
Thanks in anticipation of any advice.
  • 4 more comments
  • Starkey999 May 31, 2008
    Hi, where is the filter on the wf540 please?
  • Anonymous Jun 28, 2008
    wont work and wash enhance lights flash with on/off
  • shaunr Jul 06, 2008
    we have a hotpoint wf540 1400 spin & it fille up with water then wont start & the pre wash light flashes.
    at 1 point the water gushed out of the soap dispencer.
    please help
    We have a hotpoint wf540 1400 spin & it fille up with water then
    wont start & the pre wash light flashes and at 1 point the water
    Just wandered where the filter is at the front of the washer please.
    Thanks Shaun
  • bobbi1402 Mar 25, 2009
    I just rented a flat with a brand newly fitted HotPoint Aquarius WF560 and using the machine for the first time, it got stuck, with Wash enhance (Button 1), Rinse hold (Button 2) and the On/Off button flashing. I have tried draining and using a different program but stilll the same issue, so I just spined out the water and going to scream at my landlord for this, cos it seems every appliance they have installed is below standard that they all have faults.
    Jake.
  • hippopants May 15, 2009
    washer fills gets stuck mid cycle pre wash flashes at times ... then have to stop it and put it on spin to empty n water comes out the dispenser drawer
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1605
Points
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
  • Anonymous May 16, 2008
    And yes it is a little sh*t to unscrew... Let me know if you have any problems and i will do my best to explain how you can use a spanner and an adjustable to do it..
    Cheers
    Dobby
1helpful
Hotpoint wf540 rinse hold and on/off light flashing
if the machine is old the front panel need to be service.Probably the front panel is experiencing partial contact with he control buttons.
Hotpoint fault codes
try a different store.
2helpful
Hi My Hotpoint WF540 1400 spin is stopping mid cycle and not draining, rinsing and spinning unless I stop the cycle and choose just rinse and spin. Any suggestions? sarah
Probably needs the filter cleaning.
Remove lower rear panel.
Remove large black hose onto drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump itself.
Please rate my solution.
Thanks.
3helpful
2answers
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
On/off switch and mini load switch flashes simultaniously
yes its the pcb cause u should not leave a washing machine on a standby mode
u should always unplug it
1helpful
Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
2answers
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
15helpful
4answers
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
Lights flashing but machine not working
hi there i would check the connections to the heater and ntc both can be found behind the lower inspection cover at the rear, UNPLUG FROM MAINS FIRST AS LIVE PARTS EXPOSSED BEHIND!!!
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
