Someplace near the carburetor should be an idle mix screw and an idle speed screw. There may also be a high-speed mix screw. Try turning the idle speed screw in 1/4-turn at a time until it idles. If you turn it too far, the clutch will always be engaged so the blade will never stop.
Once you get it to idle, adjust the idle mix screw in or out 1/4-turn at a time until it idles at the highest speed. Turn the mix screw in JUST until the idle speed starts to drop a little, then back it out 1/4 turn.
Now adjust the idle speed screw again until it idles smoothly at a low enough speed that the blade stops.
This sounds like a micro switch acting up, the first switch to check is the seat switch, make sure the block connecter is pushed fully home on the switch ( there is often a fail safe inside the connecter should the block come away from the switch )
This one the best brands on the market that I have ever owned.
If the fan motor will not turn on or hums and/or turns slowly more than likely its a lubrication problem.
1. Unplug the fan from the wall remove the 516 screws to the cage
2. Try turning the fan blade by hand if it is tough to turn more than likely it's a lubrication problem
3. You will have two oil holes one in the front one in the back spray WD-40 into these holes, turn the fan blade if it starts to free it up apply more WD-40 and keep turning the blade add more WD-40 until the blade turns freely. Especially in the rear oil hole because this is an oiled bushing that you are adding oil to. Once the fan is turning freely replace the front cage with all the screws plug the fan and I hope this solves your problem. You may add 3 in 1 oil or some other very light lubricating oil periodically.
Electric hand saw has become a must-have power tool once you have a woodworking workshop whether it's for home usage, hobby, or industrial purposes.
These electric saws help you obtain more precision cuts and get the woodcutting job done more efficiently, effortlessly. However, there are different electric hand saw products for cutting wood available in the market. https://dailytoolsguide.com/best-electric-hand-saw-for-cutting-wood/
Electric hand saws have variants for which they're specifically designed. What you need is the best electric hand saw for cutting wood that suits your needs. We've listed some electric handsaw products you may consider below.
Try inserting an allen wrench in the hole at the bottom center of the unit and turning clockwise. Once you feel the resistance give way, the blades are turning freely. Hit the re-set button (also on the bottom of the unit). Run water and pulse a few times to clear whatever was blocking the blades.
There is somthing in the PTO that is binding up. I am assuming the PTO is for the mower blades. The belt(s) could be binding up, not on the pulleys, etc. The blades should turn by hand easily.
