There might be a problem either with the program you are using or with nokia 6600 .if you are using facing problem with program try to reinstall that file,but if you think that your mobile is having problem than you can format your mobile or flash your mobile .When you flash your mobile ,it will become new as you you purchased means factory settings....
A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to “Nokia” screen (may flash “Nokia” 4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive. WARNING: This will ERASE EVERYTHING on your phone
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
If this answers your question please rate this as fixed.
If you need more help just add a comment and I'll be glad to help you further... Thanks
dilipbagdi - [email protected]
I'm using NOKIA 7610 , From my application manager i close the phone app by mistake , After that my mobile is close all the app and showing NOKIA window for 10 sec and BLANK and again showing NOKIA window , Please give me the solution
